BEGA Lighting New member Monday at 4:46 AM #61 Architectural Recessed Step and Wall Light for Indoor and Outdoor Installation BEGA Lighting Jun 9, 2025 outdoor step lights outdoor wall lights These recessed luminaires are designed for installation in walls or stair risers, offering both... Upvote 0 Downvote
BEGA Lighting New member Monday at 4:46 AM #62 Low-Mount Recessed Wall Fixture with Stainless Steel Trims for Modern Architecture BEGA Lighting Jun 9, 2025 outdoor wall lights These large-format recessed wall luminaires are available with either unshielded light or... Upvote 0 Downvote
FX Luminaire New member Monday at 4:47 AM #63 Outdoor LED Up/Down Wall Sconce with RGBW, Luxor Zoning and Dimming Control FX Luminaire Jun 1, 2025 outdoor wall lights The NL Up/Down Light is a sleek, wall-mounted geometric fixture designed for both downlight and... Upvote 0 Downvote
FX Luminaire New member Monday at 4:47 AM #64 Recessed Wall-Mounted LED Lights for Stairways and Wide Footpaths BEGA Lighting Jun 9, 2025 outdoor lighting outdoor wall lights For decades, BEGA luminaires from this series have served as iconic lighting elements on... Upvote 0 Downvote
FX Luminaire New member Monday at 4:48 AM #65 Outdoor LED Down Light for Narrow Posts, Perimeter Fencing, Pool Enclosures, Columns, Doorways, and Pergolas FX Luminaire Jun 1, 2025 outdoor wall lights The QL down light is a compact and efficient lighting solution, measuring just 1.5 inches (38... Upvote 0 Downvote
FX Luminaire New member Monday at 4:49 AM #66 Low-Profile Dimmable Outdoor LED Wall Light with Zoning Control Using Luxor Smart Lighting System FX Luminaire Jun 1, 2025 outdoor wall lights The HS wall light is a modern, low-profile LED fixture designed for recessed applications... Upvote 0 Downvote
FX Luminaire New member Monday at 4:49 AM #67 Low-Voltage Outdoor Hardscape Wall Light for Under Cap and Railing Installations FX Luminaire Jun 1, 2025 outdoor wall lights The LF LED Wall Light is a compact, durable under-the-cap hardscape lighting solution designed... Upvote 0 Downvote
FX Luminaire New member Monday at 4:49 AM #68 Recessed LED Wall Light for Downward Illumination in Stairway and Pathway Applications with Integrated Luxor Control FX Luminaire Jun 1, 2025 garden lighting outdoor lighting outdoor wall lights The LM LED Wall Light is designed for projects that require a higher level of illumination while... Upvote 0 Downvote
FX Luminaire New member Monday at 4:50 AM #69 Low Voltage Outdoor Brass LED Wall Light with PWM/Phase Dimmable Control FX Luminaire Jun 1, 2025 outdoor wall lights The MS LED Wall Light is a standout addition to the FX Luminaire LED line, building on the... Upvote 0 Downvote
FX Luminaire New member Monday at 4:50 AM #70 Dark-Sky Compliant Recessed LED Wall Light for Exterior Pathway and Accent Lighting FX Luminaire Jun 1, 2025 outdoor wall lights The PD LED Wall Light features an organic design similar to the UN model but offers a higher... Upvote 0 Downvote
FX Luminaire New member Monday at 4:51 AM #71 Recessed Outdoor Wall Light for Outdoor Walkway and Stair Safety Lighting FX Luminaire Jun 1, 2025 outdoor wall lights The PO LED Wall Light is designed to provide glare-free illumination, ensuring guests can move... Upvote 0 Downvote
FX Luminaire New member Monday at 4:51 AM #72 Weatherproof Outdoor Recessed Wall/Step Light for Low-Profile Vertical Installation FX Luminaire Jun 1, 2025 outdoor step lights outdoor wall lights The RH Recessed Wall/Step Light is designed for sleek, seamless integration, making it a modern... Upvote 0 Downvote
FX Luminaire New member Monday at 4:51 AM #73 Surface-Mounted Outdoor Wall and Step Light with Specialized Optics for Wall-Washing and Ground-Washing Effects FX Luminaire Jun 1, 2025 outdoor step lights outdoor wall lights The SF Surface-Mounted Wall Light offers a sleek and modern lighting solution that simplifies... Upvote 0 Downvote
FX Luminaire New member Monday at 4:52 AM #74 Outdoor Dimmable LED Wall Light with Adjustable Color Temperature and Glare-Free Shielding FX Luminaire Jun 1, 2025 outdoor wall lights The SL Wall Light is a compact and versatile fixture engineered for both performance and design... Upvote 0 Downvote
FX Luminaire New member Monday at 4:52 AM #75 Outdoor Color-Changing RGBW Silicone LED Strip Light for Patios, Stairs, and Hardscape FX Luminaire Jun 1, 2025 led neon flex The SRP RGBW LED Strip Light is a vibrant and flexible lighting solution designed to enhance a... Upvote 0 Downvote
