Lumascape New member Dec 7, 2025 #61 Surface-Mount Direct View LED Linear Fixture for Architectural Lighting and Dynamic Color Displays Lumascape May 28, 2025 facade lighting led pixel lighting linear architectural lighting pixel mapping lights The Vestalux V2 is a high-performance direct view linear outliner built to impress, engineered... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #62 Waterproof Direct Burial Inground LED Landscape Fixture with Stainless Steel Construction Lumascape May 28, 2025 inground lights The Inground LS9401LED is an exceptionally versatile luminaire designed to meet a range of... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #63 In-Ground and Wall Mounted LED Luminaire with Darksky Compliance, Drive-Over Rating Lumascape May 28, 2025 inground lights outdoor wall lights The Vedita VE8 is a compact, high-performance luminaire designed for in-ground or wall-mounted... Upvote 0 Downvote
GVA Lighting New member Dec 7, 2025 #64 Inground Linear White Light LED Fixture for Monochromatic Wall Washing and Grazing GVA Lighting May 26, 2025 inground lights wall washer lights The STR9® Inground Mono is a high-performance, monochromatic linear LED luminaire designed for... Upvote 0 Downvote
GVA Lighting New member Dec 7, 2025 #65 Linear Inground Pixel-Controlled LED Wall Washer and Grazer for Architectural Façade Lighting GVA Lighting May 26, 2025 facade lighting inground lights wall washer lights The STR9® Inground Color Changing luminaire is a high-performance, linear inground LED fixture... Upvote 0 Downvote
GVA Lighting New member Dec 7, 2025 #66 Tunable White Linear Inground LED Wall Washer and Grazer for Outdoor Architectural Lighting GVA Lighting May 25, 2025 inground lights linear architectural lighting wall washer lights The INGROUND Dynamic White is a high-performance linear LED luminaire engineered for wall... Upvote 0 Downvote
GVA Lighting New member Dec 7, 2025 #67 Outdoor Linear LED Wall Washing and Grazing Fixture with Integrated Drivers for Architectural Accent Lighting GVA Lighting May 25, 2025 inground lights wall washer lights The STR9®W is a high-performance monochromatic linear LED luminaire designed specifically for... Upvote 0 Downvote
Griven New member Dec 7, 2025 #68 In-Ground RGBW LED Recessed Wall Grazer and Uplighter with Pixel Mapping, Walk-Over Durability Griven May 23, 2025 exterior architectural lighting inground lights The PARADE L Recessed RGBW series offers a high-performance solution for architectural in-ground... Upvote 0 Downvote
Griven New member Dec 7, 2025 #69 RGBW In-Ground LED Uplighter with Adjustable Beam Angle for Exterior Landscape and Architectural Lighting Griven May 23, 2025 inground lights landscape lighting outdoor lighting DUNE MK3 RGBW is a high-performance LED recessed uplighter engineered specifically for exterior... Upvote 0 Downvote
Griven New member Dec 7, 2025 #70 Recessed LED Uplight with DMX Control, Tunable White Technology, and High Load-Bearing Capability Griven May 23, 2025 inground lights RUBY R DW is a high-performance LED uplighter specifically engineered for exterior recessed... Upvote 0 Downvote
Griven New member Dec 7, 2025 #71 Ground Recessed LED Uplighter with Tunable White Light for Exterior Wall Grazing and Spot Lighting Griven May 23, 2025 inground lights RUBY MC R DW is a high-performance exterior recessed uplighter engineered for demanding... Upvote 0 Downvote
Griven New member Dec 7, 2025 #72 IP67 Walk-Over Recessed/In-Ground LED Light Bar with Uniform White Light Output and Dynamic Pixel Effects Griven May 23, 2025 exterior architectural lighting inground lights The PARADE L4 RECESSED white light bars are high-performance, in-ground linear luminaires... Upvote 0 Downvote
Griven New member Dec 7, 2025 #73 Inground LED Fixture with Dynamic White Tuning and Optional Pixel Control for Architectural Lighting Griven May 22, 2025 exterior architectural lighting inground lights The PARADE L2 RECESSED Dynamic White is a powerful in-ground linear lighting solution designed... Upvote 0 Downvote
Griven New member Dec 7, 2025 #74 Outdoor Walk-Over In-Ground LED Linear Light for Architectural Wall Grazing Griven May 22, 2025 facade lighting inground lights The PARADE L1 RECESSED DW is a high-performance, walk-over linear recessed luminaire designed... Upvote 0 Downvote
Color Kinetics New member Dec 7, 2025 #75 BurstScape In-Grade RGBW LED Luminaire for Landscape and Architectural Lighting Color Kinetics May 21, 2025 exterior architectural lighting inground lights outdoor lighting BurstScape is a next-generation in-grade lighting solution that delivers high-quality... Upvote 0 Downvote
