CLS LED New member Dec 7, 2025 #46 Tunable White DMX LED Inground Lighting Fixture for Landscape and Architectural Applications CLS LED May 29, 2025 inground lights The Revo Inground Tunable White DMX lighting fixture is an ideal solution for outdoor... Upvote 0 Downvote
CLS LED New member Dec 7, 2025 #47 DMX Outdoor Inground LED Lighting Fixture with Adjustable RGBW/RGBA/AWB Color Mixing CLS LED May 29, 2025 color changing lights inground lights The Revo ColourFlow is an exceptionally versatile outdoor lighting fixture designed to produce a... Upvote 0 Downvote
CLS LED New member Dec 7, 2025 #48 20W LED Inground Light with Adjustable Beam Angle and Dimmable Driver Options CLS LED May 29, 2025 inground lights The Revo Inground is a high-performance, sustainable lighting fixture designed for demanding... Upvote 0 Downvote
CLS LED New member Dec 7, 2025 #49 10W Inground LED Uplight for Landscape, Pathway, and Façade Lighting CLS LED May 29, 2025 inground lights outdoor lighting The Revo Compact Inground is a powerful and sustainable lighting fixture designed for... Upvote 0 Downvote
CLS LED New member Dec 7, 2025 #50 5W Inground LED Uplight with IK10 Impact Rating and IP67 Waterproof Protection CLS LED May 29, 2025 inground lights The Revo Micro Inground is a compact, high-performance outdoor lighting fixture designed for... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #51 Linear Inground LED Fixture with RGBA, RGBW, Tunable White, and Static White Options for Continuous Run Outdoor Installations Lumascape May 28, 2025 inground lights outdoor lighting The linear inground fixture described here is a high-output lighting solution that blends... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #52 In-Ground LED Uplight for Drive-Over, Architectural Façade, Hardscape, and Outdoor Landscape Lighting Lumascape May 28, 2025 inground lights The Erden E6 is a medium-powered, shallow-depth in-ground luminaire designed to deliver... Upvote 0 Downvote
FX Luminaire New member Dec 7, 2025 #53 High-Power In-Ground LED Fixture with Static White, RGBW, RGBA, and Tunable White Light Options Lumascape May 28, 2025 inground lights The Erden E8 is a high-powered in-ground luminaire that merges cutting-edge technology with... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #54 High-Power In-Ground LED Fixture with Static White, RGBW, RGBA, and Tunable White Light Options Lumascape May 28, 2025 inground lights The Erden E8 is a high-powered in-ground luminaire that merges cutting-edge technology with... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #55 Shallow Depth Outdoor LED In-Ground Light for Landscape, Planters, and Concrete Installation Lumascape May 28, 2025 inground lights The Evoca EV7 is a compact, shallow-depth in-ground luminaire designed specifically for... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #56 In-Ground/Wall-Mounted LED Luminaire with IP68 Waterproofing, IK10 Impact Resistance, and PWM Dimming Control Lumascape May 28, 2025 inground lights The Vedita VE8 is a compact and versatile luminaire designed for both in-ground and wall-mounted... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #57 Compact Recessed LED Luminaire for In-Ground and Wall-Mounted Installations with DMX/DALI/0-10V Dimming Lumascape May 28, 2025 inground lights The Vedita VE9 is a compact and versatile luminaire designed for both in-ground and wall-mounted... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #58 Side-Emitting Marker Light for Pathways, Pedestrian Areas, and Low-Speed Traffic Zones with IP68 and IK10 Rating Lumascape May 28, 2025 inground lights outdoor lighting The LS553LED Via is a durable, side-emitting marker light specifically engineered for public... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #59 Reversible Angled and Flat-Top LED Well Light with RGBW Color Capability Lumascape May 28, 2025 inground lights The nVault-15 is a versatile well light featuring a reversible angled or flat-top design... Upvote 0 Downvote
Lumascape New member Dec 7, 2025 #60 Cylindrical Brass In-Grade LED Luminaire for Commercial and Residential Landscape Lighting Lumascape May 28, 2025 inground lights The nColumn-10 is a cylindrical in-grade luminaire designed with versatile faceplate options... Upvote 0 Downvote
