Industrial grade tubular LED luminaires are enclosed and gasketed light fixtures designed to fulfill the demanding needs of industrial applications. They deliver a wide or omnidirectional light distribution that make them advantageous for applications where a high illuminance level on both vertical and horizontal planes is required. These products look similar to tubular LED retrofit lamps but are independent of each other in design concept. They are self-contained lighting systems created from the ground up with an intention to unlock the full efficiency and performance potential of LED lighting. Industrial grade tubular LED luminaires are intended for both indoor and outdoor installations which are also subject to rough environmental conditions, such as heat, cold, dust, humidity, corrosive atmosphere.
