American Lighting New member 19 minutes ago #31 Static White Flexible LED Neon Strip for Seamless Direct-View Architectural Cove and Accent Lighting American Lighting Aug 15, 2025 1 led neon flex The NeonFlex Pro flexible LED neon strip light represents a next-generation solution for... Upvote 0 Downvote
QTL New member 19 minutes ago #32 Flexible RGB LED Neon Strip Lights for Outdoor Architectural Lighting with DMX Control QTL Aug 25, 2025 1 led neon flex The FLEX RGB LED Neon Strip Light series is a versatile and visually dynamic solution for... Upvote 0 Downvote
GENLED Acolyte New member 19 minutes ago #33 RGBW Color Changing Square 3D LED Neon Flex for Architectural and Decorative Lighting Applications GENLED Acolyte Aug 31, 2025 1 led neon flex The Apex 3D is a versatile square-faced LED neon fixture designed to deliver exceptional visual... Upvote 0 Downvote
Environmental Lights New member 18 minutes ago #34 360 Degree Flexible LED Neon Strip Light for Architectural, Stage, and Event Lighting Projects Environmental Lights Aug 21, 2025 1 led neon flex The Eluxtra™ 360° flexible LED neon strip light is designed to deliver seamless and uniform... Upvote 0 Downvote
QTL New member 18 minutes ago #35 IP68 Flexible LED Neon Strip Lights for Submersible Pool and Spa Accent Lighting Installations QTL Aug 25, 2025 1 led neon flex wet location lighting The Pool and Spa Flexible LED Neon Strip Lights are designed for underwater and outdoor lighting... Upvote 0 Downvote
GENLED Acolyte New member 17 minutes ago #36 Waterproof Round Flexible LED Neon Tube with Pixel RGBW Control for Media Facades and Dynamic Displays GENLED Acolyte Aug 31, 2025 1 led neon flex Neon360 is a fully flexible LED neon tube that combines the smooth, timeless glow of traditional... Upvote 0 Downvote
Environmental Lights New member 17 minutes ago #37 RGB+3000K LED Neon Strip Light with UCS2904 IC for Smooth Pixel Gradients and Dynamic Animations Environmental Lights Aug 20, 2025 1 individually addressable led lighting led neon flex The Eluxtra™ ProFlex PixelControl 4-in-1 LED Neon Strip Light is a versatile, high-performance... Upvote 0 Downvote
Environmental Lights New member 16 minutes ago #38 Wide Top LED Neon Strip Light with RGBW Dynamic Pixel Effects for Indoor and Outdoor Architectural Installations Environmental Lights Aug 20, 2025 1 individually addressable led lighting led neon flex The Eluxtra™ ProFlex PixelControl 4-in-1 Wide Top LED Neon strip light is a professional-grade... Upvote 0 Downvote
Prizm Lighting New member 15 minutes ago #39 Individually Addressable Flexible RGBW LED Neon Strip Lights for Dynamic Color Changing Effects Prizm Lighting Aug 17, 2025 1 individually addressable led lighting led neon flex rgb lighting The Neoflux Pro individually addressable flexible LED neon strip lights represent the next... Upvote 0 Downvote
Prizm Lighting New member 15 minutes ago #40 Waterproof Flexible RGBW LED Neon Strip Lights with UV, Flame, and Saltwater Resistant Silicone Jacketing Prizm Lighting Aug 17, 2025 1 led neon flex rgb lighting Neoflux Pro flexible LED neon strip lights are engineered as a next-generation solution for... Upvote 0 Downvote
GENLED Acolyte New member 14 minutes ago #41 Waterproof Silicone LED Strip Light with Static White, Variable White, RGBW, and Pixel Programmable Options GENLED Acolyte Aug 30, 2025 1 led neon flex The Neon Silhouette Plus LED strip light is a high-performance, bendable, and waterproof... Upvote 0 Downvote
American Lighting New member 14 minutes ago #42 Flexible LED Neon Strip Light with Three-Sided Emission for Smooth Diffused Lighting American Lighting Aug 16, 2025 1 led neon flex The Minuet flexible LED neon strip light is designed to deliver smooth, evenly diffused... Upvote 0 Downvote
American Lighting New member 14 minutes ago #43 Single Color LED Neon Flexible Strip Lighting for Indoor and Outdoor Architectural Applications American Lighting Aug 15, 2025 1 led neon flex The NeonFlex Pro represents the next generation in seamless, direct-view architectural lighting... Upvote 0 Downvote
LIFX New member 13 minutes ago #44 LIFX Neon Flex Smart LED Strip Light for Gaming, TV Backlighting, and Room Accents LIFX Jun 30, 2025 led strip lights smart lighting The LIFX SuperColor Indoor Neon Flex is a revolutionary lighting solution designed to bring... Upvote 0 Downvote
American Lighting New member 13 minutes ago #45 Single Color Flexible LED Neon Strip Light for Coastal, Marine, and Outdoor Lighting Projects American Lighting Aug 15, 2025 1 led neon flex Neonflex Pro represents the next evolution in single-color flexible LED neon lighting... Upvote 0 Downvote
QTL New member 13 minutes ago #46 Black Flexible Side-Bend LED Neon Strip Lights for Indoor and Outdoor Architectural Lighting QTL Aug 25, 2025 1 led neon flex The Black Flexible LED Neon Strip Lights with side bend capabilities are engineered for... Upvote 0 Downvote
American Lighting New member 12 minutes ago #47 High CRI 90+ 3000K Flexible LED Neon Strip with IP67 Sealed Silicone Jacketing American Lighting Aug 15, 2025 1 led neon flex The Neonflex Pro represents the next generation of flexible neon LED strip lighting, designed to... Upvote 0 Downvote
American Lighting New member 12 minutes ago #48 IP68 RGB LED Neon Strip Light for Underwater Pool and Fountain Lighting Installations American Lighting Aug 14, 2025 1 led strip lights The pool-rated RGB LED neon strip light is a premium linear luminaire designed specifically for... Upvote 0 Downvote
American Lighting New member 11 minutes ago #49 Static White Flexible LED Neon Strip Light with Sealed Silicone Jacketing for Cove, Accent, and Façade Lighting American Lighting Aug 15, 2025 1 led neon flex Neonflex Pro represents the next generation of static white flexible LED neon strip lighting... Upvote 0 Downvote
American Lighting New member 11 minutes ago #50 Turtle Friendly Amber Neon LED Strip Light for Direct View and Coastal Outdoor Applications American Lighting Aug 15, 2025 1 led neon flex The MicroLux 620nm Turtle Friendly Neon LED Strip Light is a next-generation, fully encased tape... Upvote 0 Downvote
FX Luminaire New member 9 minutes ago #51 Outdoor Color-Changing RGBW Silicone LED Strip Light for Patios, Stairs, and Hardscape FX Luminaire Jun 1, 2025 led neon flex The SRP RGBW LED Strip Light is a vibrant and flexible lighting solution designed to enhance a... Upvote 0 Downvote
Acclaim Lighting New member 9 minutes ago #52 IP68 Outdoor-Rated Flexible LED Strip Lights - LED Neon Flex with Addressable Control or Architectural Facade, Cove, and Direct View Lighting Acclaim Lighting May 22, 2025 architectural lighting led neon flex led strip lights linear architectural lighting The Flex Tube series offers a versatile range of high-performance, flexible LED strips... Upvote 0 Downvote
Griven New member 9 minutes ago #53 Warm/Natural White Output Flexible LED Neon Strip Light for Architectural and Landscape Lighting Griven May 23, 2025 led neon flex led strip lights The KRAIT MB 1616 W is a flexible, direct-view LED strip designed to deliver elegant white light... Upvote 0 Downvote
QTL New member 8 minutes ago #54 Red, Green, Blue, Amber LED Neon Strip Lights with IP67 Waterproof Silicone Housing QTL Aug 25, 2025 1 led neon flex The QUBE FLEX Light series provides an exceptional lighting solution for applications where... Upvote 0 Downvote
QTL New member 8 minutes ago #55 Impact-Resistant Flexible Neon LED Strip Light with Side Bend Design and Seamless Continuous Run Options QTL Aug 25, 2025 1 led neon flex This flexible neon LED strip light is a highly durable, impact-resistant micro-fixture designed... Upvote 0 Downvote
QTL New member 8 minutes ago #56 High CRI Flexible LED Neon Strip Light with Up/Down Bending and IK10 Impact Resistance QTL Aug 25, 2025 1 led neon flex This fully encapsulated flexible LED fixture combines durability, versatility, and design... Upvote 0 Downvote
QTL New member 7 minutes ago #57 High-CRI Static White Flexible LED Neon Light with Helical and Vertical Bend Options QTL Aug 25, 2025 1 led neon flex This flexible micro-fixture is a highly versatile LED neon strip light designed for creative... Upvote 0 Downvote
American Lighting New member 7 minutes ago #58 24V RGBW Color Changing LED Neon Strip Light with DMX Dimming Control for Dynamic Architectural Lighting American Lighting Aug 15, 2025 1 led neon flex NeonFlex Pro represents the latest evolution in architectural-grade direct view lighting... Upvote 0 Downvote
Glamox New member 6 minutes ago #59 Marine-Grade IP67 Flexible LED Neon Strip for Interior and Exterior Decorative Lighting Glamox Jun 20, 2025 led neon flex The AL46 Atlantis LED neon strip light is part of the Glamox AL46 family, which includes FL for... Upvote 0 Downvote
Thorn Lighting New member 6 minutes ago #60 Side and Top Bend Flexible Linear LED Neon Strip Light with Dynamic White/RGBW Control Thorn Lighting Sep 9, 2025 1 led neon flex Mystrid Flex is a versatile family of flexible linear LED neon luminaires designed to deliver... Upvote 0 Downvote
