Color Kinetics New member Today at 2:22 AM #10 iColor Accent Compact RGBW Linear LED Fixture with Ethernet Control for Architectural Media and Dynamic Visual Effects Color Kinetics May 21, 2025 dynamic architectural lighting exterior architectural lighting facade lighting linear architectural lighting The iColor Accent Compact RGBW is a high-resolution, direct-view linear LED luminaire designed... Upvote 0 Downvote
Blizzard Lighting New member Today at 8:39 AM #15 Pixel Mapping RGBW LED Bar with Vibrant Color Mixing for Synchronized Visual Sequences Blizzard Lighting Nov 19, 2025 1 color changing lights individually addressable led lighting pixel mapping lights rgb led flood lights rgb lighting stage wash lights The Infinipix Arcade RGBW LED pixel bar redefines what a lighting fixture can do, delivering... Upvote 0 Downvote
EXC-LED New member Today at 8:43 AM #16 RGB/RGBW Direct-View LED Linear Fixture with 8-Pixel 8bit/16bit Grayscale Color Control EXC-LED May 24, 2025 facade lighting linear architectural lighting The EXC-U20NDB0 Linear Direct-View Fixture is a high-performance, ultra-narrow LED lighting... Upvote 0 Downvote
EXC-LED New member Today at 8:43 AM #17 RGB/RGBW Linear LED Direct-View Light for Architectural Accent and Digital Display Applications EXC-LED May 24, 2025 facade lighting linear architectural lighting pixel mapping lights The EXC-D30AB is a high-performance, extra-narrow linear direct-view LED fixture engineered for... Upvote 0 Downvote
Lumascape New member Today at 8:45 AM #18 Surface-Mount Direct View LED Linear Fixture for Architectural Lighting and Dynamic Color Displays Lumascape May 28, 2025 facade lighting led pixel lighting linear architectural lighting pixel mapping lights The Vestalux V2 is a high-performance direct view linear outliner built to impress, engineered... Upvote 0 Downvote
GVA Lighting New member Today at 8:45 AM #19 Modular Pixel-Addressable Dynamic White Linear LED Fixture for Architectural Accent and Direct View Applications GVA Lighting May 26, 2025 facade lighting linear architectural lighting pixel mapping lights The HL-GEN4 DYNAMIC WHITE is the fourth-generation modular LED lighting system in GVA’s HL... Upvote 0 Downvote
GVA Lighting New member Today at 8:46 AM #20 Direct View Linear LED Light with 75mm Pixel Resolution and Long-Run Capability for Architectural Facades and Accents GVA Lighting May 26, 2025 linear architectural lighting pixel mapping lights The HL-GEN4 MONO is the fourth-generation monochromatic modular LED lighting system in GVA... Upvote 0 Downvote
GVA Lighting New member Today at 8:47 AM #21 Direct View Color-Changing Modular Linear LED Fixture for Dynamic Architectural Facade Lighting GVA Lighting May 26, 2025 facade lighting linear architectural lighting pixel mapping lights The HL-GEN4 COLOR CHANGING is the fourth-generation modular LED lighting system in GVA's... Upvote 0 Downvote
Griven New member Today at 8:47 AM #22 Ultra-Slim Direct-View RGB/RGBW Pixel-Mapping Linear LED Fixtures for High-Resolution Graphic Façade Lighting Griven May 23, 2025 facade lighting linear architectural lighting pixel mapping lights The GRAPH-I-PIX CLEAR series from GRIVEN offers a high-performance, ultra-slim direct-view... Upvote 0 Downvote
Acclaim Lighting New member Today at 8:49 AM #23 Terra Linear Recessed LED Marker and In-Ground Light for Pathway, and Landscape Applications Acclaim Lighting May 22, 2025 exterior architectural lighting inground lights landscape lighting linear architectural lighting outdoor lighting Terra Linear is Acclaim Lighting’s next-generation in-ground linear LED series, designed from... Upvote 0 Downvote
