Clampco Sistemi New member 18 minutes ago #31 ICAO Type A + C Explosion Proof Dual-Mode Medium Intensity White and Red Obstruction Light for Aviation Safety Clampco Sistemi Jul 31, 2025 aviation obstruction lights explosion proof lighting The MIOLAC-E1_23S is an advanced ICAO Type A + Type C medium intensity obstruction light... Upvote 0 Downvote
Clampco Sistemi New member 18 minutes ago #32 Low Intensity Red LED Obstruction Beacon with Solar Power for Remote Hazard Lighting Applications Clampco Sistemi Jul 31, 2025 aviation obstruction lights The ACWL_SOLAR03 is a solar-powered low intensity red obstruction light engineered specifically... Upvote 0 Downvote
Clampco Sistemi New member 18 minutes ago #33 ICAO Type A + B Solar-Powered Low-Intensity LED Obstruction Light for Remote Aviation Hazard Marking Clampco Sistemi Jul 31, 2025 aviation obstruction lights The ACWL_SOLAR04 is a solar-powered, low-intensity red obstruction light engineered to meet both... Upvote 0 Downvote
Clampco Sistemi New member 18 minutes ago #34 Solar-Powered Medium-Intensity ICAO Type B Obstruction Light for Aviation Safety Applications Clampco Sistemi Jul 31, 2025 aviation obstruction lights The ACWL_SOLAR05 is a solar-powered, medium-intensity white obstruction light designed for... Upvote 0 Downvote
Clampco Sistemi New member 17 minutes ago #35 Low-Intensity LED Obstruction Light with Integrated Redundancy for Power Lines and Broadcast Towers Clampco Sistemi Jul 31, 2025 aviation obstruction lights The SEGDxxA32_1 is a low-intensity red obstruction light specifically designed to meet ICAO Type... Upvote 0 Downvote
Clampco Sistemi New member 17 minutes ago #36 Medium Intensity White LED Obstruction Light for Chimneys, Towers, Cranes, and High Buildings Clampco Sistemi Jul 31, 2025 aviation obstruction lights The MIOLA-M1_23S is a high-performance medium intensity white obstruction light designed to... Upvote 0 Downvote
Avlite New member 16 minutes ago #37 Solar LED Obstruction Light for Temporary Barricade and Hazard Marking with Automatic Night Activation Avlite Jul 31, 2025 aviation obstruction lights The AV-OL-70 Solar Obstruction and Barricade Light is a rugged, self-contained solar-powered LED... Upvote 0 Downvote
Avlite New member 16 minutes ago #38 Solar-Powered ICAO Type A Low Intensity Obstruction Light with Bluetooth and Optional Satcom or GSM Connectivity Avlite Jul 31, 2025 aviation obstruction lights The AV-OL-75 is a compact, solar-powered, ICAO Type A Low Intensity Obstruction Light engineered... Upvote 0 Downvote
Avlite New member 15 minutes ago #39 Self-Contained Solar LED Obstruction Light Compliant with FAA L-810 and ICAO Type A/B for Towers and Wind Turbines Avlite Jul 31, 2025 aviation obstruction lights Avlite’s AV-OL-310 is a self-contained, solar-powered, steady-burning low intensity LED... Upvote 0 Downvote
Avlite New member 15 minutes ago #40 FAA and ICAO Certified Low Intensity LED Obstruction Light with Concurrent Visible and IR Output Avlite Jul 31, 2025 aviation obstruction lights The AV-OL-LI is a cutting-edge low-intensity obstruction light engineered to meet the latest FAA... Upvote 0 Downvote
Avlite New member 12 minutes ago #41 Universal Voltage LED Obstruction Light (12–48VDC / 110–240VAC) with Photocell for Day/Night Operation Avlite Jul 31, 2025 aviation obstruction lights The AV-OL-ILAB Low Intensity Obstruction Light by Avlite is a steady-burning, energy-efficient... Upvote 0 Downvote
Obelux New member 11 minutes ago #42 High-Intensity White LED Aviation Obstruction Light for Wind Turbines and Tall Structures Obelux Jul 30, 2025 aviation obstruction lights The Obelux high-intensity stand-alone 200,000 candela aviation obstruction light is engineered... Upvote 0 Downvote
Obelux New member 10 minutes ago #43 High-Intensity White LED Aviation Obstruction Light with Integrated GPS and Modbus Connectivity Obelux Jul 30, 2025 aviation obstruction lights The Obelux high-intensity Type B obstruction light, delivering an impressive 100,000 candela... Upvote 0 Downvote
Obelux New member 9 minutes ago #44 High-Intensity 50,000cd White LED Aviation Obstruction Light for Wind Turbines and Tall Structures Obelux Jul 30, 2025 aviation obstruction lights The Obelux high-intensity stand-alone white light with a luminous intensity of 50,000 cd... Upvote 0 Downvote
Obelux New member 9 minutes ago #45 ICAO Medium-Intensity Type B/C Red LED Obstruction Light with NVG Infrared and GPS Synchronization for Offshore Wind Turbines Obelux Jul 30, 2025 aviation obstruction lights The Obelux medium-intensity Type B/C obstruction light, delivering 2,000 candela in aviation... Upvote 0 Downvote
Obelux New member 8 minutes ago #46 FAA Certified Medium-Intensity L-864/L-885 Aviation Red 2,000cd LED Obstruction Light with Integrated Fault Monitoring and Photocell Obelux Jul 30, 2025 aviation obstruction lights The Obelux medium-intensity stand-alone red obstruction light, delivering 2,000 candela, is... Upvote 0 Downvote
Obelux New member 8 minutes ago #47 ICAO Certified Medium-Intensity Type A LED Obstruction Light with Integrated GPS and Modbus LAN TCP/IP Connectivity Obelux Jul 30, 2025 aviation obstruction lights The Obelux medium-intensity white obstruction light, delivering 2,000 candela flashing output... Upvote 0 Downvote
Obelux New member 8 minutes ago #48 Mexican AESA Certified Medium-Intensity Red Aviation Obstruction Light with Integrated Fault Monitoring and GPS Synchronization Obelux Jul 30, 2025 aviation obstruction lights The Obelux medium-intensity stand-alone 2,000 candela red obstruction light is specifically... Upvote 0 Downvote
Obelux New member 7 minutes ago #49 German-Certified Medium-Intensity LED Obstruction Light with W, rot ES Red Flashing for Wind Turbine Marking Obelux Jul 30, 2025 aviation obstruction lights The Obelux medium-intensity stand-alone obstruction light, featuring a 20,000 candela white... Upvote 0 Downvote
Obelux New member 7 minutes ago #50 Medium-Intensity Aviation Red and White LED Obstruction Light with GPS Synchronization for Tall Structures Obelux Jul 30, 2025 aviation obstruction lights The Obelux medium-intensity stand-alone obstruction light model delivers a powerful 20,000... Upvote 0 Downvote
Obelux New member 7 minutes ago #51 Through-the-Wall LED Aviation Obstruction Lights for Wind Turbine Tower Intermediate Level Marking Obelux Jul 30, 2025 aviation obstruction lights The Obelux LIT series represents a specialized low-intensity obstruction lighting solution... Upvote 0 Downvote
Obelux New member 6 minutes ago #52 Portable Battery Powered Low-Intensity LED Obstruction Light with Aviation Red and NVG-Compatible Infrared Obelux Jul 30, 2025 aviation obstruction lights The Obelux Low-Intensity Portable (LI-P) obstruction light is a compact, battery-operated LED... Upvote 0 Downvote
Obelux New member 6 minutes ago #53 Multi-National Certified LED Obstruction Light with ICAO, FAA, German AVV, and Nordic Approvals Obelux Jul 30, 2025 aviation obstruction lights The Obelux low-intensity LED obstruction light series is purpose-built for marking tall... Upvote 0 Downvote
Obelux New member 6 minutes ago #54 Low-Intensity LED Obstruction Light for Hindernisfeuer ES Compliance with German AVV Regulations Obelux Jul 30, 2025 aviation obstruction lights The Obelux low-intensity 10cd LED obstruction light, certified as Hindernisfeuer and... Upvote 0 Downvote
Obelux New member 5 minutes ago #55 German AVV-Compliant Low-Intensity LED Aviation Beacon with Infrared NVG Capability Obelux Jul 30, 2025 aviation obstruction lights The Obelux low-intensity 170cd model W, rot ES is a high-performance aviation obstruction light... Upvote 0 Downvote
Obelux New member 5 minutes ago #56 CASA Certified Low-Intensity LED Obstruction Lights with GPS Synchronization and Modbus Connectivity Obelux Jul 30, 2025 aviation obstruction lights The CASA (Australia) Low-Intensity Stand-alone Obstruction Light series from Obelux is... Upvote 0 Downvote
Obelux New member 5 minutes ago #57 Swiss AD I-006 Certified Low and Medium Intensity LED Aviation Obstruction Lights with NVG Compatibility Obelux Jul 30, 2025 aviation obstruction lights The Obelux low- and medium-intensity red obstruction lights, compliant with Swiss AD I-006... Upvote 0 Downvote
Obelux New member 4 minutes ago #58 CAP 168 Certified 200cd Low-Intensity LED Obstruction Light for Wind Turbines and Tall Structures Obelux Jul 30, 2025 aviation obstruction lights The Obelux CAP 168 Low-Intensity 200cd Stand-alone aviation obstruction light is a reliable and... Upvote 0 Downvote
Obelux New member 4 minutes ago #59 Infrared 850nm LED Aviation Obstruction Light with MOD UK Certification for Military and Civil Applications Obelux Jul 30, 2025 aviation obstruction lights The Obelux IR850-048-CST infrared LED obstruction light is a high-performance... Upvote 0 Downvote
S4GA New member 2 minutes ago #60 Wireless-Controlled Solar Aviation Obstruction Light with ICAO Type A Compliance S4GA Jul 29, 2025 aviation obstruction lights The SP-401 is a solar-powered, low-intensity aviation obstruction light (Type A) designed to... Upvote 0 Downvote
