S4GA New member 49 minutes ago #31 Portable Runway Edge Lights with FAA /ICAO Compliance for Remote and Temporary Airfield Operations S4GA Jul 28, 2025 aeronautical lighting The SP-102 Portable Runway Edge Light is an advanced and reliable lighting solution designed for... Upvote 0 Downvote
ADB Safegate New member 45 minutes ago #32 ICAO-Compliant Omnidirectional Elevated Turnpad LED Light for Runway Edge and Taxiway Applications ADB Safegate Jul 29, 2025 aeronautical lighting The RELIANCE® Omnidirectional Elevated Turnpad Light is a medium-intensity LED lighting solution... Upvote 0 Downvote
ADB Safegate New member 45 minutes ago #33 LED High-Intensity Modular Elevated Airfield Lighting System for Runway, Approach, and Stop Bar Applications ADB Safegate Jul 29, 2025 aeronautical lighting airport lighting AXON LED high-intensity elevated lights represent a cutting-edge solution for modern airfield... Upvote 0 Downvote
Eaton Lighting New member 44 minutes ago #34 High Intensity LED Runway Edge and Threshold Light with Canada TP312 Certification Eaton Lighting Aug 2, 2025 aeronautical lighting The PRO APF TP312 HIRL is a high-intensity LED runway edge light designed to serve multiple... Upvote 0 Downvote
S4GA New member 44 minutes ago #35 Battery-Powered White/Red Runway Edge Light for Temporary and Remote Airfields S4GA Jul 28, 2025 aeronautical lighting The Medium Intensity Portable Runway Edge Light (White/Red) by S4GA is a versatile and rapidly... Upvote 0 Downvote
Eaton Lighting New member 42 minutes ago #36 L-861 MIRL LED Medium Intensity Runway Edge Light with FAA AC 150/5345-46 Certification Eaton Lighting Aug 2, 2025 aeronautical lighting The PRO APF L-861 MIRL is an advanced LED fixture designed for use as a medium intensity runway... Upvote 0 Downvote
Avlite New member 42 minutes ago #37 Voltage-Driven LED Runway End Identifier Light with Adjustable Flash Intensity for Commercial Airports Avlite Jul 31, 2025 aeronautical lighting The FTS 812(L) is a high-performance LED runway threshold identification light (RTIL), also... Upvote 0 Downvote
Eaton Lighting New member 41 minutes ago #38 LED Medium Intensity Runway Edge Light with Canada TP312 5th Edition Certification Eaton Lighting Aug 2, 2025 aeronautical lighting The PRO APF TP312 MIRL is a versatile LED lighting fixture designed for use as a medium... Upvote 0 Downvote
S4GA New member 40 minutes ago #39 ICAO-Compliant Portable Threshold End Runway Light with Red/Green LED Output for Remote Airfields S4GA Jul 28, 2025 aeronautical lighting The S4GA Medium Intensity Portable Runway Threshold End Light is a robust, battery-powered... Upvote 0 Downvote
S4GA New member 38 minutes ago #40 Portable Runway Obstruction Light for Temporary and Emergency Airfield Lighting Solutions S4GA Jul 28, 2025 aviation obstruction lights The S4GA portable runway obstruction light provides a dependable and versatile solution for... Upvote 0 Downvote
S4GA New member 36 minutes ago #41 ICAO and FAA-Compliant Solar Runway Edge Light for Permanent and Temporary Displaced Threshold Installations S4GA Jul 29, 2025 aeronautical lighting The SP-401 is a state-of-the-art solar-powered medium intensity runway edge light designed... Upvote 0 Downvote
Friars New member 34 minutes ago #42 ICAO-Compliant Elevated Threshold Wing Bar Light for Enhanced Runway Safety and Guidance Friars Jul 30, 2025 aeronautical lighting The TKH Elevated Threshold Wing Bar Light 797 THRW is a robust and versatile LED lighting... Upvote 0 Downvote
Obelux New member 32 minutes ago #43 High-Intensity LED Runway End Identification Light with NVG-Compatible Infrared Output Obelux Jul 30, 2025 aeronautical lighting The Runway End Identification Light (REIL) is an advanced airfield lighting solution engineered... Upvote 0 Downvote
ADB Safegate New member 29 minutes ago #44 Intelligent LED Stopway Light with Integrated ILCMS Remote Control ADB Safegate Jul 29, 2025 aeronautical lighting The RELIANCE elevated LED light fixture is a unidirectional lighting solution specifically... Upvote 0 Downvote
S4GA New member 23 minutes ago #45 Solar-Powered ICAO-Compliant Medium Intensity Runway Threshold Light for Civil and Military Airports S4GA Jul 29, 2025 aeronautical lighting The SP-401 Solar Runway Threshold Light is a high-performance, solar-powered, medium-intensity... Upvote 0 Downvote
