Hella Marine New member Nov 29, 2025 #16 Sealed and UV-Resistant Compact LED Utility Light for Boat Engine Rooms and Storage Lockers Hella Marine Jul 15, 2025 marine lighting utility lighting The DuraLED12 Heavy Duty Lamps from Hella marine are compact yet powerful lighting solutions... Upvote 0 Downvote
Hella Marine New member Nov 29, 2025 #17 Low Profile LED Utility Lights for Boat Engine Rooms and Storage Compartments Hella Marine Jul 15, 2025 marine lighting The DuraLED20 and DuraLED36 Heavy Duty Interior lamps from Hella marine are powerful... Upvote 0 Downvote
Hella Marine New member Nov 29, 2025 #18 Heavy Duty Marine Interior Lamp for Storage Lockers, Lazarettes, Utility and Mechanical Rooms Hella Marine Jul 15, 2025 marine lighting The DuraLED50 Heavy Duty Interior lamp is a powerful, low-profile lighting solution designed to... Upvote 0 Downvote
Glamox New member Nov 29, 2025 #19 DNV-Compliant LED Indoor Lighting Fixture with EMC1 and EMC2 Variants Glamox Jun 20, 2025 marine lighting The AL40N-R is a highly efficient recessed luminaire specifically designed according to DNV... Upvote 0 Downvote
Glamox New member Nov 29, 2025 #20 Low-Voltage LED Task Light with EMC 1/Class B Certification for Marine Navigation and Control Rooms Glamox Jun 20, 2025 marine lighting task lighting The Chart Lamp T LED is a versatile task light designed for professional environments where... Upvote 0 Downvote
Glamox New member Nov 29, 2025 #21 UL-Certified LED Ceiling Light for Marine Cabins with Emergency Battery Backup Glamox Jun 20, 2025 marine lighting The GIM RT (CM) 600 LED UL is a ceiling-mounted luminaire specifically developed for... Upvote 0 Downvote
Glamox New member Nov 29, 2025 #22 Shock-Resistant LED Fixture for Ceiling or Tray Mounting in Maritime and Industrial Environments Glamox Jun 20, 2025 marine lighting The TL60N LED is an innovative outdoor lighting fixture designed for a wide range of demanding... Upvote 0 Downvote
Glamox New member Nov 29, 2025 #23 Dimmable LED Marine Chart Light with White and Night Vision Goggles-Compatible Green Modes Glamox Jun 20, 2025 marine lighting The 1934 Chart Table Light has undergone a recent redesign featuring upgraded white and green... Upvote 0 Downvote
Glamox New member Nov 29, 2025 #24 Recessed LED Emergency Light with Integrated Battery Backup for Marine Applications Glamox Jun 20, 2025 emergency backup lighting marine lighting The E85-R(M) is a recessed-mount emergency and escape route luminaire built on advanced LED... Upvote 0 Downvote
Glamox New member Nov 29, 2025 #25 Explosion-Proof Zone 1 LED Luminaire with Wide Temperature Range for Offshore and Onshore Applications Glamox Jun 20, 2025 explosion proof lighting marine lighting The TX60 LED luminaire is an innovative lighting solution designed for hazardous areas, setting... Upvote 0 Downvote
