Applicable to both indoor and outdoor locations, catenary lighting solutions, where luminaires are strung on an overhead catenary system (OCS), allow light to be delivered exactly where it is needed without the obtrusive installation of high density light poles, columns, and other ground-based support structures. The introduction of catenary lighting addresses the need for maximized use of activity areas in residential and commercial environments. A catenary lighting system consists of luminaires, catenary cables, power cords that run in parallel with catenary cables, the mounting mechanism for mechanical attachment of luminaires, and accessories for suspending catenary cables between two support structures. Depending on the span of overhead spaces as well as the luminaire distribution requirement, the catenary suspension system can be designed as a single cable catenary system, linear grid catenary system, central spine catenary system, or central ring catenary system.
